To be sure things are OK, the Ignition switch on a mag is a Kill switch. There is only one wire attached, and the switch body is grounded. When the button is out, the switch is open, and the mag makes spark. When the switch is pushed in, it is closed, mag primary current goes to ground and the mag makes no spark. The tractor can be started by pulling, or cranking. Take the wires off of the Generator, and it will be fine. Removing the belt is even better (as noted below). JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
