Wiring harness question for Farmall H
Posted by sflem849 on September 12, 2009 at 18:20:57 from (66.254.196.101):
I bought a new wiring harness to install on my 42 H. But the problem is I don't have the heart to put a beautiful reproduction on a FILTHY tractor. I plan on painting the machine within a year and just want to test run it until then. I don't need electric start, pull starting is ok. I don't need lights.
The tractor has voltage regulator on generator and magneto ignition. IIRC this means you can run it without a battery and not cause harm.
THE BIG QUESTION:
Can I just make a wire to run from the mag to the switch and not use any of the other wires?
Will it wreck the generator not having a battery?
Will I need to make up any other wires?
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
