Re: F504 Diesel: What Parts To Change on a Clutch Swap?
Posted by Hugh MacKay on September 13, 2009 at 18:34:30 from (209.226.247.75):
In Reply to: Re: F504 Diesel: What Parts To Change on a Clutch Swap? posted by charles todd on September 13, 2009 at 18:06:48:
Charles: The big benefit of installing this loose is two splined shafts, PTO going into pressure plater and drive line going into clutch disc.
Back in the days of transmission driven PTO, one just engaged the PTO, got someone to stand at back and turn shaft to line splines in clutch disc. You can still do this with IPTO, however IPTO doesn't turn easy by hand and you have to jack one rear wheel to turn transmission shaft. Not an easy feat as you try to roll tractor together.
