Re: F504 Diesel: What Parts To Change on a Clutch Swap?
Posted by charles todd on September 13, 2009 at 18:06:48 from (205.242.95.137):
In Reply to: F504 Diesel: What Parts To Change on a Clutch Swap? posted by charles todd on September 13, 2009 at 00:48:06:
So is this 1.188 in inches? As in 1" and 188 thousandths? Also, what is the benefit of installing the clutch and pressure plate loose, then tightening up after bolting the bellhousing? Is this for alignment issues? I believe there is enough room to get inside through the access cover. Can I change the rear main (engine) at this time? Should I change the front transmission seal as well?
CT
