Re: What's missing from 560?
Posted by D Slater on September 14, 2009 at 06:29:11 from (71.164.37.9):
In Reply to: What's missing from 560? posted by Matt_in_Michigan on September 14, 2009 at 05:47:22:
Think you are mixed up, if the cover you removed is a flate steel plate its the cover under main clutch, short nipple and grease fitting was in the release bearing sleeve at one time. Bathtub shaped cast cover is under pto and hydraulic pump drive gear and is just to rear of the other cover. Other 2 holes may be the drain holes for the t/a clutch compartment thats supposed to stay dry.
