Re: 756 PTO
Posted by Mazemeister on September 14, 2009 at 17:30:56 from (24.188.81.230):
In Reply to: Re: 756 PTO posted by pete 23 on September 13, 2009 at 19:53:36:
if that little pin is broken, you should be able to pull the control valve spool up out the top of the pto unit. when the 2 halves of the spool are properly connected, it goes in/out through the bottom. this requires either removing lots of the 3 point hitch or pulling the pto unit.
i'd agree; if the pto worked fine, then suddenly quit, i'd suspect the little pin. that's just a couple bucks from the CIH dealer.
