Re: Farmall 100 need help identifying bolts
Posted by TractormanNC on September 16, 2009 at 04:43:33 from (209.42.180.131):
In Reply to: Farmall 100 need help identifying bolts posted by couv on September 15, 2009 at 19:21:51:
Hey Couv,
The bolts at the pump end are indeed 3/8 fine thread with a lockwasher and nut. IIRC they are a special length. Standard grade 5 bolts of the correct length will work fine.
At the block end, standard grade 5 bolts of the correct length will work fine. Sorry can't help with the length. IIRC there are NO lockwashers under these bolt heads.
HTH
