Re: Farmall M burns POINTS!!!!
Posted by John T on September 16, 2009 at 10:22:17 from (66.244.97.31):
In Reply to: Farmall M burns POINTS!!!! posted by deerediesel on September 16, 2009 at 08:31:25:
If the Ballast Resistor is sized correctly to match the coil, Id expect more like 5 to 7 volts on the coils input WHEN POINTS ARE CLOSED. If youre putting 11 volts on a 6 volt coil the intended points n coil current is nearly doubled and the coil runs hot plus the points burn up prematurely. Also if the condensor is weak or open the points burn up much sooner but your problem sounds like not enough ballast resistance.
Typical ballast resistors for 12 volt systens rrunning 6 volt coils are in the 1.5 to 2 ohms range, you may wanna check yours.. Or else get a full true (some call internally ballasted) 12 votl coil no ballast required.
John T
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
