Farmall M burns POINTS!!!!
Posted by deerediesel on September 16, 2009 at 08:31:25 from (207.160.145.13):
i have a 1943 Farmall M and it runs good for just a little while after installing a new set of points then maybee after 5 mins the points start to burn and it starts to run roung.. sand the points down and it will run good for awile again. It was 6V converted to 12 and it does have a resitor iline to to wire to the coil. I checked voltage going to coil with tractor off and it was 11V and about 12V when running.. What should the voltage be going to the coil when tractor is running? or is there anything else that could lead to this problem. Thanks
