Posted by B Peppler on September 18, 2009 at 06:12:39 from (205.213.216.254):
Hello can anybody give me the Fram / NAPA numbers for the engine oil cartridge and the hydro filters on a 340 utility. Also what can I do to get remotes to the rear of the tractor for a cylinder. The only lever is the one for the 3 point. This is a 1961 year made tractor did IH give 3 point as an option on this tractor. It does not have the fast hitch / zip hitch on it. Thanks Brian
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
