farmall 14 wide front
Posted by f826 on September 18, 2009 at 21:00:50 from (174.124.221.110):
i have a f14 with steel cut downs on the front. i bought a pair of spoke rims and want to change them and found the berrings are not interchangeable. an old guy told me long ago he did just this. has any one else run in to this problem and did you find the right berrings. i have been to the auto parts and only found the inner berring. thanks
