Posted by Dave Allgire on September 19, 2009 at 06:28:59 from (96.35.216.238):
In Reply to: farmall 14 wide front posted by f826 on September 18, 2009 at 21:00:50:
I"m in the process of restoring a wide front for my F-14. I"m also replacing the bearings and the original ones seem to fit correctly. Inner bearing numbers on mine are Timken #2785 and the outer bearing is a Timken #1775. Whoever you order your bearings from will be able to provide you with the correct races for these bearings. Hope this helps.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
