Posted by sgtbull on September 19, 2009 at 05:43:32 from (163.191.228.254):
I've been restoring tractors for almost 25 years now, and as of late have noticed a new quirk. Few years ago I rebuilt a '40 H completely. New pistons, rings, sleeves, etc and a professionally rebuilt head. I've noticed that when I first start the tractor up, I get a slight misting of water droplets. Not white smoke and not unburned fuel, but it does leave little black specks all over the place. It doesn't have any water in the crankcase or creamy oil, and my water level isn't going down. Now, I've restored three different tractors in the last year, (two cubs and a B), and all of them exhibit similar characteristics. Has anyone else seen this? I could see ONE headgasket maybe having a leak after assembly, but 4? I usually use an aviation grade head sealant and out of 35 tractors I've redone, I've had NO head gasket leaks. Interstingly enough, I have 4 JD two cylinders, and none of them show the same spray, even though they use the same fuel. I'm using 89 octane w/ 10 ethanol...which is about all you can get around here in the midwest it seems.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
