Re: My new M needs help
Posted by Janicholson on September 20, 2009 at 19:53:42 from (64.61.212.83):
In Reply to: My new M needs help posted by KC Bob on September 20, 2009 at 18:44:26:
Bent is possible, but if 4th works fine, it is worn out teeth on 5th. It is a direct input to output shaft using sliding splines on the inside of 4th gear, and the input shaft. It is not hard to fix compared to splitting, but it will require taking off the trans platform, and the Belly pump, as well as the belt pulley if it has one. to gain access. JimN
