Posted by Bob M on September 22, 2009 at 11:05:08 from (151.190.254.108):
In Reply to: Generator on M posted by Bill in IL on September 22, 2009 at 07:22:15:
Good advice offered by the other posters below. A couple more thoughts however:
1 – Your observed charging voltage of 6.7 volts is a bit on the low side. 7.1 to 7.4 volts is preferred. (This of course presumes your voltmeter is accurate - it may not be!). Means the VR relay may need a tweak to bring its set voltage up a few tenths.
2 – Assuming stock lamps (with a stock bulb inside each lamp...) a healthy generator and regulator will not supply adequate current for the lights and ignition until the engine’s running at about 2/3 throttle. Running slower has the lights consuming more current than the generator can put out. The battery then makes up the difference by slowly discharging. The only way then to make it charge is to throttle up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
