300 Utility Hydraulic Problems
Posted by 56Utility on September 22, 2009 at 13:31:56 from (65.55.67.195):
I have two 300 utility tractors. Each one has one hydraulic problem. On the first tractor the fast hitch will bleed down and drop all the way down after sitting overnight. Do I have a check valve that is leaking? On the second tractor it has a McCormick U34B loader and when I drive it the lift cylinders extend and retract a lot causing the bucket to bounce up and down. Do I have air trapped in the system? Thank you in advance for any advice.
