Re: 300 Utility Hydraulic Problems
Posted by MARK ROBKE on September 23, 2009 at 18:55:38 from (67.140.177.255):
In Reply to: 300 Utility Hydraulic Problems posted by 56Utility on September 22, 2009 at 13:31:56:
ON YOUR FAST HITCH BLEEDING DOWN,I THINK THE CHECK VALVE IS THE BLOCK UNDER THE CONTROL LEVER BLOCK;IT HAS A NAME LIKE CROSS CHECK?? VALVE. ON YOUR LOADER I THINK IT IS AIR IN THE CYLINDERS;MINE WAS LIKE THAT AFTER UNHOOKING IT ALL SUMMER AND THEN PUTTING IT ON: AFTER USING IT THE AIR SELF BLED OUT. MY FAST HITCH WON'T BLEED DOWN IF IT SITS HOLDING AN IMPLEMENT UP FOR A MONTH. MARK
