Re: Maybe I'm slow, but I need a little more help
Posted by Dave S. on September 23, 2009 at 05:07:07 from (208.92.169.136):
In Reply to: Maybe I'm slow, but I need a little more help posted by Mike CA on September 22, 2009 at 21:10:07:
Mike, the shaft and retainer in the picture will slide out of the housing. The bearing is holding it(probably rust). Get a slide hammer puller or something similar and attach to holes where pulley fastens and pull it out.
There is nothing inside holding it in.
Check the bearings, they may be pitted and rough from years of non-use and moisture collecting in gearbox.
