Maybe I'm slow, but I need a little more help
Posted by Mike CA on September 22, 2009 at 21:10:07 from (99.28.152.102):
I was told this...
wayne in mn said: ...Remove the capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance.
Remove the cap screw on the end of the shaft and all the parts can be pulled off...
I thought the "cap screw" meant on the end of the pulley mount, in the center, which you can see on the picture below. But no such luck, unless I'm not seeing it because it's covered in dirt? If not, then where are these cap screws that will help me put this belt pulley back together?
