Re: Maybe I'm slow, but I need a little more help
Posted by ScottyHOMEy on September 23, 2009 at 05:58:38 from (70.105.228.226):
In Reply to: Maybe I'm slow, but I need a little more help posted by Mike CA on September 22, 2009 at 21:10:07:
Cap screw is just another name for a bolt.
So the first part refers to the three cap screws around the retainer, the ones that you already have out.
The second part seems to refer to the cap screw that holds the bevel gear on the INNER end of the pulley shaft, to allow you to slip the assorted bearings, spacers, washers and seals and the retainer off of the shaft. (According to the parts books, some have a shaft machined to take a washer and slotted nut instead of a cap screw in that spot.) The bolt in question in this second part I don't think is at all relevant to you getting this thing back into place and bolted down.
