Re: Main transmission shaft backlash
Posted by CenTex Farmall on September 23, 2009 at 08:24:42 from (166.128.18.52):
In Reply to: Main transmission shaft backlash posted by Gordon Mercer on September 22, 2009 at 17:44:27:
The .008 to .012 is between the gear teeth and as Jim is saying it is measured by using a dial indicator with a magnetic base set up to read off of a gear tooth.
You want the dial indicator set up to be perpendicular to the gear teeth and the ring gear is the most practical to use.
