Posted by Gordon Mercer on September 22, 2009 at 17:44:27 from (24.230.119.203):
As a new member to this forum, I have a question I hope someone can answer. I was plowing snow last winter and my transmission started knocking. I split my tractor in two and found what the problem was. The bearing between the main transmission shaft and the transmission drive shaft was bad and the nose of the main shaft was damaged. I purchased a used main shaft today and and a drive shaft. The main shaft is mounted at the rear of the transmission with a triangular plate. there are several shims under this plate which set the gear backlash. Since I am replacing the main shaft with a different one from a different tractor. I need to set the backlash by adding or subtracting shims. I don,t know what the backlash specs are. If anyone knows this, please let me know. Thanks, Gordon Mercer, Spearfish, SD
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
