Re: The H.....
Posted by gene bender on September 24, 2009 at 02:28:45 from (67.55.226.179):
In Reply to: The H..... posted by Bill in IL on September 23, 2009 at 19:59:34:
A clutch is a clutch when using a common clutch with pressure plate you need a good bearing and the fingers adjusted so they are even play out of all the moving linkage and it will work just fine. Even the return spring so the throw out bearing does not touch the fingers when released. The clutch on the H doesent have any special features.
