Re: 48 H Seat
Posted by wfd2 on September 25, 2009 at 17:41:30 from (173.100.116.59):
In Reply to: 48 H Seat posted by Bill47 Perry on September 25, 2009 at 17:24:44:
Hi Bill,
I had the same problem but ended up breaking off the bolt on the left side because of rust.
The bolts have the same type threads, counterclockwise turns loosen the bolts.
Did you try spraying WD-40 into the side where you removed the bolt and let it sit overnight? Then try using thin-nosed vise grips to hold the rubber bushing on the side with the stuck bolt.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
