The tractor that I was going to take the valves off of, Had two pipe plugs in the front of the first valve body, just as you described. It has a Ford power Steering pump powering a Char-lynn actuator, so it does not need to use that valve at all for the P.S..
The first valve on this tractor did not have any openings in the front of the valve body.
I thought that the Behlen P.S. system got its power from the bottom of the Safety/regulator valve. Can you tell me about that so that I can put the correct valve back on this tractor? I have a Behlen system also, that is not working now and maybe I need to swap this one valve to get it to work. SDE
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
