Re: 400 hydraulic system problem
Posted by D Slater on September 25, 2009 at 15:20:10 from (71.164.37.9):
In Reply to: 400 hydraulic system problem posted by SDE on September 25, 2009 at 14:50:29:
Thats used with a power steering regulator and saftey valve. If you have a regular regulator leave it out. Did the valve beside that just have one opening for a line in the front or 2 openings like the other valves?
