Re: Water jacket plate leaking around bolt holes
Posted by Mike CA on September 27, 2009 at 10:17:04 from (99.28.152.102):
In Reply to: Water jacket plate leaking around bolt holes posted by Allan Kropelnicki on September 27, 2009 at 08:56:28:
I've got a similar problem with one of my bolts. I was going to remove and replace the gasket (I figured removing the current one will ruin it) and I was going to go crazy with the black gasket goop I've got. I think I used some before, but maybe not enough, and maybe not in all the areas it needed, like close to the bolts.
If at first you don't succeed... cuss.
