Re: Water jacket plate leaking around bolt holes
Posted by John G. Hasler on September 27, 2009 at 11:20:23 from (174.124.28.201):
In Reply to: Re: Water jacket plate leaking around bolt holes posted by Mike CA on September 27, 2009 at 10:17:04:
Don"t "go crazy" with it: the excess will just ooze out and plug things up. Apply a thin coat to the casting over the entire area that will be contacted by the gasket (be sure and go all the way around every bolt hole) and press the gasket on. Then do the same to the entire gasket, again being careful to go all the way around the bolt holes.
