Re: Water jacket plate leaking around bolt holes
Posted by CNKS on September 27, 2009 at 10:23:26 from (216.144.104.128):
In Reply to: Water jacket plate leaking around bolt holes posted by Allan Kropelnicki on September 27, 2009 at 08:56:28:
What rustred says. I don't remember if that gasket is cork, if so excessive tightening will probably make it leak more because you are compressing it too much and also bending the plate. It's probably not cork as it's water, most cork is used for oil. If it's leaking it may be bent already. If what rustred says does not work, remove, straighten and use another gasket, along with the silicone. As to the rest of the gasket, I have had good luck with copper coat. I don't use a torque wrench on lightly tightened bolts.
