Re: Water jacket plate leaking around bolt holes
Posted by Allan kropelnicki on September 27, 2009 at 11:36:37 from (142.161.247.40):
In Reply to: Re: Water jacket plate leaking around bolt holes posted by CNKS on September 27, 2009 at 10:23:26:
This was a brand new plate and new gasket, not cork type, but its not leaking around the gasket that meets the side block, its a little dribble around the bolt heads, i used a flat washer on each bolt as not to compress it unevenly, but, it has ever so little leak on a couple of bolts, maybe i am being to picky, perhaps it will form rust and stop it?? lol. I was told by the dealer DO NOT use any compound on it???? before i installed the set, now i am thinking he was wrong!!!
