Loren: Cub 22 is a side or center mount mower for Cub only. There is a SA 22 but it is different for mounting to SA.
The No. 16 is a fully mounted rear mower, has different mounting hardware depending on tractor. A-16 fits A or SA, C-16 fits C or SC and H-M-16 fits H, M, SH and SM. In all cases drawbar must be removed. A mower bolts to final drives, and others all bolt to axle carriers, difference between C and H-M is size of axle carriers. As I recall PTO shaft does run a bit offset on C, H and M, quite straight on A or SA due to offset PTO.
The A-16 was available in 7' version, Being fully mounted it created enough rear weight, one needed front wheel weights. I used a 7' semi-mount on my 130 for years, tail wheel made the rear weight situation much better. I had my semi-mount equipped so I could use it on either Farmall 130 or 300. The 300 would not out mow the 130, even in hill country. 130 was agile enough it more than made up for 300 power and weight.
Those semi-mount mowers all had model numbers in twenties, same basic mowing device as the 16, but a different mounting frame with a caster wheel at back. Much faster mower to hitch and unhitch as it bolted to drawbar cross bar. When used on a C or SC tractor was equipped with drawbar similar to an H.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
