Posted by jdbrad1 on September 28, 2009 at 05:23:34 from (216.116.87.110):
I have a 340 with a 6 volt system that starts and runs fine when the engine is cold, but once I have started it and ran it to the point that it heats up to normal running temp the engine is hard to start if I kill it and try to restart. The coil is warm to the touch, but is not so hot that I can't touch it. The battery test out fine and is new, less than a month old. What would make the tractor so hard to start after it is hot? If I let the tractor set for a while and cool down it will start right up with out any problems.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
