Three things I would check first. The starter motor might be beginning to drag internally (worn bushings) and when it is hot, it has more drag than when cold (thousandths of an inch make a drastic change) The cables might be small, When cold, copper conducts substantially better than when hot. 0gauge cables are really important. Car type #4 cables loose power at 6v under load. Using a cheap (less than 15$) starter draw amp meter (auto store tool that is held against the battery cable, no connection required) should show about 300 amps. If more like 400 to 450, the starter needs to be looked at. Sometimes advanced timing can also cause slight pushback at TDC. slowing cranking when warm and the fuel is easily fired up. JimN
Today's Featured Article - Harry Ferguson - The Man & The Machine Harry Ferguson was christened Henry George but every one called him Harry. Harry was born in a small Irish town called Growell in County Down about 16 miles from Belfast. Harry Ferguson led a varied and colorful childhood causing mischief where ever he could. He showed mechanical aptitude at a very early stage in life and showed no inclination towards
... [Read Article]
Latest Ad:
[More Ads]
