340 utility extra hydraulics remotes to the back of tractor
Posted by B Peppler on September 29, 2009 at 06:18:28 from (205.213.216.254):
Hello I have a 340 utility and would like to know what I can do to get a set of remotes or to hook up a cylinder to the rear of the tractor to use on a disk. This tractor has the one valve for the 3 point/fast hitch and no other. It does not look like I can run a set of hoses out of the main hydro valve and then to a control valve. I see on Case IH parts that the extra valves and stuff are retried. Thank you, Brian
