A generator shot and was off a Chrysler
Posted by tackhammertime on September 29, 2009 at 17:25:50 from (72.155.5.129):
When I changed my H over to 12 volts with alt. instead of gen no big deal. I have tried in past post to find conversion of A to 12 volt with alt. I am probably blind but I cant find a post. How does this work with the pos. ground. mag ignition. Thought about just buying a 6volt battery tender and not worrying about it.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
