Posted by john *.?-!.* cub owner on September 30, 2009 at 20:00:08 from (75.120.49.32):
In Reply to: Cub overhaul posted by jimmyD on September 30, 2009 at 18:19:36:
remove the oil filter cover. there is a hole on the inside opposite the gauge. use a can to pump oil in there till it is full. crank with starter a little to make sure oil is flowing. once it is, put cover back on and try it. you have just primed the oil pump,. needing to do that is normal after overhaul of cub.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
