I remove the radiator just because its easier then the u-bolt is out of the way to remove the axle. Then i do replace all the seasl. You will need to put thread sealer on the big nut when replacing so it doesent leak any 90wt when im finished. With new seals ,bushings and the bearing i dont have any leaks. Make sure the spindles get grease to the bottom where the flange seats. They will steer like new and easy when finished. You mite need to use a disc sander to get the ball ends on the tie-rods round again.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
