Re: oil filter case retaining bolt Gasket
Posted by ScottyHOMEy on October 02, 2009 at 03:25:57 from (70.105.249.216):
In Reply to: Re: oil filter case retaining bolt Gasket posted by Byron F Stone on October 01, 2009 at 18:45:02:
CaseIHNHFord sells them as part #13727D.
As luck would have it, that's the same as a couple I have here. Measured em up and got
ID -- 11/16"
OD -- 7/8"
Thick -- 1/16"
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
