Re: Surging Govenor....Now What?????
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by The Red with another Thought on April 21, 2000 at 06:14:04 from (12.75.196.213):
In Reply to: Surging Govenor....Now What????? posted by Ed Fisher on April 20, 2000 at 07:20:43:
I saw the comments over on ATIS also Ed. Seems like we have a stumper.
Place the throttle lever in idle.
Unbolt the carburetor from the manifold but leave it hooked up to the governor shaft.
Remove the upper angled plate from the governor housing.
Now stick you finger on the throttle butterfly to keep it closed. Wiggle the throttle shaft and see if you have some play. If it has play then I would suspect where the governor throttle shaft fits into the slot on the carb. throttle shaft is worn.
If it is tight, then we are back to square one at the moment.
Post A Followup
: Re: Re: Surging Govenor....Now What?????
