Surging Govenor....Now What?????
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Ed Fisher on April 20, 2000 at 07:20:43 from (208.246.136.52):
Well I've tried everything mentioned including: Checking for vacuum leaks
Binding linkage
Worn throttle shaft
Worn govenor shafts
Timing
Dirty carburetor
Miss adjusted linkages
Dirty air breather
Bad govenor spring
Water in fuel
any problems found were corrected but still no success. Any other ideas??????? Thanks. Ed.
Post A Followup
: Re: Surging Govenor....Now What?????
