Re: fuel leak on M
Posted by RustyFarmall on October 02, 2009 at 11:48:27 from (209.152.78.140):
In Reply to: Re: fuel leak on M posted by nydolphin on October 02, 2009 at 10:51:46:
The gaskets are all the same. Likewise the needle valve and seat, so no problem there, but if you bought that sediment bowl assembly at a farm supply type store, you most likely are going to be disappointed.
