Re: Farmall Super A - Surging
Posted by ScottyHOMEy on October 02, 2009 at 17:37:28 from (64.222.246.201):
In Reply to: Farmall Super A - Surging posted by JBann on October 02, 2009 at 16:28:45:
A couple/three quick thoughts.
If you've got that left-side linkage set up, I tend to suspect the carb, either the float or a bit of crud that broke loose and got lodged somewhere in the cleaning process.
The only thing that will usually go wrong with a governor in a hurry is the main spring breaking. If it was okay when you took it apart, I wouldn't bother about that.
As far as the bumper spring, (it shouldn't give out suddenly either) you do have the acorn-style jam nut off of it, right? Sillier things have happened, but the adjustment is on what looks like a full-threaded slot-head set screw. It is covered and jammed in place by an acorn nut over the top (or bottom, in this case). If you're trying to turn the acorn nut in to cure the surge, you won't be getting anywhere.
My money's on the carb.
