Re: Farmall Super A - Surging
Posted by JBann on October 02, 2009 at 18:57:08 from (70.44.147.219):
In Reply to: Re: Farmall Super A - Surging posted by ScottyHOMEy on October 02, 2009 at 17:37:28:
Well, in saying I have the left side linked, I mean the best I can.
I know that in order to do it properly, you put the throttle to the full gas position. Then take the carb linkage and also have it in the wide-open position. The linkage should slide right into the arm, but for some reason it doesn't. And I do know that the linkage from arm to carb can be shortened and lengthened, but I have it on the shortest setting and it still doesn't fit just right, better though than when it was longer.
But if we do rule out the governor, do you guys recommend just a new good thorough cleaning of the carb?
If there is anything else I should be looking for/doing please let me know.
This was actually the first time I worked on an engine (age 18) and I have learned quite a bit from it.
Thanks everyone
