Did you replace the bearing and put new springs in the gov assy when apart and how much play does the input shaft have as they usually wobble around a bunch. Is the linkage going to the carb adjusted correct and is there any binding in all parts of the linkage a little here and a little there all add up.The gov spring should be installed with the hooks turned correct or the spring can bind and are the holes in the gov apring linkage worn Ive been buying and selling these little tractors for a long time and have 8-10 around all the time and found out long time ago that throttle linkage and gov operation is important for good starting and throttle response.When things are in good shape they sure work better.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
