Well, I would say there is a good half inch of play in the input shaft of the governor. I adjusted the linkage to the carburetor the best I could.
When I had the governor off and open, I did not change any parts. I did notice that where the spring is hooked, that It seems to have elongated the whole where the top of the spring hooks in. To describe it better, the circle has a notch at the bottom where the spring constantly pulls down (this is for the upper portion of the spring attached to the input shaft side. Perhaps I do have to replace that arm from the input shaft the the spring?
What bearing are you talking about that I should replace? Sorry, I don't know the different parts of the governor that well.
Also, the spring looks fine (no corrosion or rust) but how can one tell if it is too worn?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
