Re: seasonal disconnect
Posted by D Slater on October 04, 2009 at 09:38:15 from (72.65.137.34):
In Reply to: seasonal disconnect posted by BernieSteffen on October 04, 2009 at 08:57:20:
The only dry cavitys in that housing is where the t/a and main clutch are located. If the transmission is filled with the tractor level, the oil will eventually flow front to rear.
Even after all drain plugs drain there will be oil traped above the seasonal disconnect and in the t/a unit cavity. Seasonal disconnect housing or plate has a oring shaft goes through and that may be leaking. If you are splitting tractor there, a bolt up inside needs removed also.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
