seasonal disconnect
Posted by BernieSteffen on October 04, 2009 at 08:57:20 from (173.25.81.198):
Currently working on 400 International. Leaks 90 wt oil at the plate on the belly where the seasonal disconnect for the pto is located.
What I need to know is,is this a dry cavity. If so why does the plate have a gasket on it. Why does it have a plug in the hole in bottom. Most dry cavitys have a drain hole in bottom to let out any unwanted oil or water. Also it has fill plug and check plug in side of cavity. Splitting tractor tommorow just would like to know whats going on. Thanks again for info. Bernie Steffen
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
