Re: seasonal disconnect
Posted by Wardner on October 04, 2009 at 09:42:27 from (4.154.247.152):
In Reply to: seasonal disconnect posted by BernieSteffen on October 04, 2009 at 08:57:20:
<a href="http://s140.photobucket.com/albums/r16/Wardner/?action=view&current=mower062.jpg" target="_blank"><img src="http://i140.photobucket.com/albums/r16/Wardner/mower062.jpg" border="0" alt="Photobucket"></a>
third party image
The tin cover with four bolts holes (bottom cavity in photo) is dry. The others are wet.
If you are splitting the tractor because the TA is not working, you should remove the the gear oil and replace it with Hy-Tran or equivalent. You need to remove three plugs to get it out. That might be the easiest TA fix you will ever do.
I am not just blowing smoke. It is how I fixed the TA on my 400. The rollers in the TA will not advance far enough to lock the one way clutch due to the gear oil's higher viscosity and absence of friction modifiers.
This post was edited by Wardner at 10:09:43 10/04/09 2 times.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
