Re: 1486 needs more power
Posted by pete 23 on October 04, 2009 at 11:34:09 from (173.87.8.73):
In Reply to: 1486 needs more power posted by Larry B 1486 on October 02, 2009 at 19:42:10:
Sounds like we are getting more smoke out of the bales now than the tractor, or maybe the keyboards. At any rate, there is another screw in that pump called the droop set points screw and some of the pumps use a different angled stop plate where the normal fuel setting screw is on and this affects the governor action especially if you are throttled down some to normal pto rpm so there fore a good dyno test of horse power at rated load speed and overload torque rise at overload speed is really the only way to compare the two tractors.
