1486 needs more power
Posted by Larry B 1486 on October 02, 2009 at 19:42:10 from (67.142.161.29):
I have a 1486 that I had the pump rebuilt hoping that it would help on the power. Had the injectors rebuilt also. The tractor starts good, uses no oil but does not have enough power. I have a 1466 also that will drag the 86 around the world backwards. I use both of them to pull a round baler that needs around 120 hp. The 66 handles it fine, under a load it opens up will pull that baler up a hill at 6-7mph and never slow down leaving black smoke seen for miles. The 86 in the same gear, most the time high 1 will pull the motor down to where I will have to pull the TA back and then lucky if I make to the top of the hill. It pulls the motor all the way down with very little smoke. they told me they turned the pump 10% up from factory. I backed out the screw myself one more turn and still don't have the power it should have. The timing is set 18 degrees. Any suggestions on getting more power?
